i have a problem when i try to write in the program.
every time i try to writhe something it is like the program makes a small glitch and then i have to pres the text box again.
it does it all the time i can write 5-6 symbols and then it jumps and sometime i have to start over again. and it is quite annoying if i have to make a long text.
it is not a computer problem because there is no problem in any other programs it is only when i use inventor.
is there a sitting i am missing or can it be because i still have the trial version for a couple of days still.
please help
Solved by mdavis22569. Go to Solution.
an example can be.
every time i make a line or others, and try to write in the dimension it glitches and i then cant make the line and must do it again and then it works the second time but every first try fails.
if i make a text box it stops at every 5-6 sign, and i have to press the text box again to continiue.
but my biggest problem is when i try to change in ex. the part list then it deletes the text every time it glitches and this means that i cant change it at all because it continues to do it all the time.
I'm not having that issue ... nor have a seen a lot of people posting about this issue ..
that's why I was wondering about an example .. So we can try and repeat it with your steps.
i will try to see if i can make a video of it.
i just have to figure out how to do that.
Use Autodesk Screencast
https://knowledge.autodesk.com/community/screencast
It's part of Inventor
there should be a video in this message.
then i hope you kan se that the text just stops sometimes when i am writing.
im not shure because it is a company computer.
but it is a HP ZBook 15uG5.
and it should be able to run the program.
What do you have for a card though?
It might not hit the spec's required:
the only thing i can find is that it is a intel(R) UHD Graphics 620.
is that what you are thinking about or is it some other informations
I wouldn't recommend using that card ...
UHD Graphics 620
Here are the certified cards:
https://knowledge.autodesk.com/certified-graphics-hardware
Do you have a 2nd card on this PC?
no this is what i have it is a new computer my boss was recommended this computer to the program but i then understand that it is not a very good computer to it.
thanks for the help. then i must talk with my boss about the computer
You might be able to get this computer to work.
Try going to Tools>Application Options>Hardware tab> Software graphics, reboot and try again.
If that works then go up the list to Conservative and see if it still works.
apparently my computer has two cards one that is not good and one that is, so i need to get to work only on the one that should be able to run it
