Problem when opening a 2024 ipt file using Inventor 2023
mbarrettMETS3
Observer Observer
Message 1 of 10
mbarrettMETS3
Observer
Observer
So I have Inventor 2023. I recently installed an update so I could open newer files. When I now open a 2024 ipt file the "Derive" command is highlighted automatically and if I click cancel the part disappears or if I say ok there is no features on display in the model browser.
When I open a file saved from 2023 Inventor there is no issue.
Any ideas why it is doing this or how to solve this?
Replies (9)
Message 2 of 10
Frederick_Law
That's how it is.
Old version cannot work on new version files.
Install 2024 to edit 2024 files.
Message 3 of 10
mbarrettMETS3
Observer
Observer
Thanks. I'll uninstall the 2023 version so and install the 2024. Thank you for the speedy response.
Message 4 of 10
Frederick_Law
You can have both on same computer.
Need to be very careful not mixing different version files.
Message 5 of 10
PRAGADEESH_K
Observer
Observer
@Frederick_Law
Is there any other option for open new version file open an old version. like conversion type...
Message 6 of 10
BDCollett
@PRAGADEESH_K wrote:
@Frederick_Law
Sometimes the latest patch will open the newer version.
Message 7 of 10
PRAGADEESH_K
Observer
Observer
Thank you @BDCollett 😊
Message 8 of 10
ldutkaTUZ58
Nope..
Message 9 of 10
johnsonshiue
Hi! Technically, there is no workflow in Inventor "opening" newer ipt/iam files in an older release. Instead, you may derive a newer ipt/iam files in an older release assuming the older release has .3 or later updates installed.
There is another workflow to consider is to export the ipt/iam files as STEP. Then you may import (convert or reference) it to an older release. The reference import option behaves very much like deriving a new ipt/iam file in an older Inventor release.
Many thanks!
Software Test Engineer
Message 10 of 10
CGBenner
@PRAGADEESH_K Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
