Announcements
Problem combine two solids
francesco.degennaroJY36U
I'm trying to complete the third practice exercise of the forth module ("Model the handle assembly"of the "Advanced Modeling for Mechanical Design" course (link below), but when I try to combine the two solids in the part drawing (first image) an error occur (second image, translation below).
https://www.autodesk.com/certification/learn/course/inventor-modeling-mechanical-design-professional...
Schermata 2023-01-24 alle 12.57.51.pngSchermata 2023-01-24 alle 12.58.16.png
Create Combine feature failed.
Grip_PE3.ipt: Errors occurred while updating.
Merge3: Cannot create Merge.
Error during operation: Merge of face-to-face intersection results failed. Use other inputs.
I'm using Inventor 2023.
Does anyone have a solution to my problem?
Thanks in advance.
CCarreiras
HI!
Maybe the software is unable to process some surface joining. These kinds of issues are normal when working with surfaces.
We can do some minor changes to help the "combine" process:
In this case, i removed some material from both sides (one or two mm is enough), and then it will work fine;
Check the file:
CCarreiras
Thank you so much for your answer, I did a direct edit of -0,5mm on both sides and the combine command works correctly.
johnsonshiue
Hi! Here is another solution using the surface modeling technique. The issue here is that the boundary patch surface has a relatively loose tolerance. It can lead to Boolean failures. It is better to have clear intersection and simplify the geometry as much as you can.
Many thanks!
Software Test Engineer
Thanks for your answer. I'm quite a new user of Inventor, could you explain me the steps please?
CCarreiras
If you don't understand the process by investigating the steps in the part, It will be not easy to explain in a few words.
Tip: Check the help for sculp tool, and don't waste too much time on that.
Following my solution, you are closer to following the tutorial with only a little correction.
Working with surfaces requires skills that a beginner doesn't have, so my advice is to finish that tutorial with success and spend more time learning other themes. In real world a few people work with surfaces, comparing with the number of people that works with solids and sheet metal...
good luck!!
CCarreiras
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
