printer problem
printer problem
printer problem
i installed a HP Laser Jet MFP M148FDW printer. when i try to print a drawing it prints a drawing that is zoomed in to the center of my drawing no matter what i do.
Cadmanto
Print to PDF and then print the PDF.  Do you get the same results?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mcgyvr
In the "Print Drawing" dialog box in Inventor select "Best Fit" instead of "Model 1:1".
Your sheet size in Inventor differs from your paper size in the printer so you must tell it to scale properly.
I have tried best fit, custom, etc. Everything prints the same. If i print to .PDF its the same. Also i can not preview.
mcgyvr
What happens when you try to preview?
Have you verified the printer works from other applications properly?
Have you tried creating a drawing with the sheet size the same as your printers default/paper size?
Have you looked at your printers settings to see if it may be adjusting the print?
What version of Inventor are you using?
Does the help button in the bottom right of the print dialog show?
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inventor-2017-The-drawing-print-preview-and-help-buttons-stopped-working-after-installing-the-Windows-10-Anniversary-update.html
Cadmanto
@Anonymous
@mcgyvr  has some excellent points.
My thoughts are do you have the latest drivers installed.  I know you said you just loaded this onto your PC, but have to check.
Can you provide some screen shots of what you are seeing that doesn't work?
I looked up some of the specs, and another thought is when I look at the paper sizes, are you crossing the metric with the english?
Inventor Pro 2021
Best Regards,
Scott McFadden
