Print all sheets, Exlude from count is checked
petrxn
petrxn
I have found thatt there is not possible to print all sheets from drawing when all sheets are marked as "Excluded from count".
Is there an workaround?
Thank you
Petr
mcgyvr
Do you have all your sheets (or all but one) set to exclude from count?
As long as you have more than one sheet not set to "exclude from count" then all sheets is available and it will print all sheets (including the ones that are set to exclude from count)..
Frankly I just don't understand the reason behind why it works like that but it does..
petrxn
I have drawing, where is finally title page and parts list only (without sheets of parts, these were deleted during revisions). Ussually we do not count this title page and pages with parts list to total pages and correct title page should show total pages = 0 in this case. Of course I can localy redefine title block of first page, but I think that this behaviour is wrong and I was not sure if there is an "correct" solution for this.
Thank you
Petr
inchul.lee
Autodesk Support
Autodesk Support
Thanks for reporting this @petrxn and @mcgyvr.
It appears that if there's only 1 or zero sheet 'included in count', then you're not able to print all sheets.
I've already reported it to our Inventor engineering team. I'll share an update in this post.
Thanks again.
Inchul Lee
