If I may request a couple of tiny little things for the next release ( It being Christmas time and all ....)
1: An option to have construction lines where the lengths are ignored .... That is to say if the line is fully defined in location and angle, then please allow Inventor to ignore the length, start and end points of it, and not complain that X number of dimensions needed. It is kinda annoying to have to select " show all degrees of freedom" just to find out that all is well except your construction lines.
2: When extruding, revolving, hole depths etc ... if someone clicks in the "value" object filed, please don't just highlight the "in" or "mm", but rather the whole value. It is a real PITA to have to click-drag the whole field to be highlighted. Unless I'm doing something wrong, currently a double click only selects the measurement ( inch or mm ) instead of the number.If I click, I can backspace just fine. But if I double click, I most likely want to change the whole shebang.
Thank you and I promise to behave even better next year .....
Solved by Jon.Dean. Go to Solution.
I will log your wish list requests with development as soon as I am back in the office. Jon
