Hello Kathy,
I have rearranged my sequence a number of times to suit my order/get around
the modifying of existing tweaks when creating a new tweak, remember the
dummy tweak you suggested, I modified that suggestion a little, basically
speaking create another tweak you will need, create the tweak that modifies
the existing tweak and and then change the order of the sequence. The
problem only happens when I play the animation in reverse, we have problem
with a product and people want to know how to disassemble the product as
opposed to assemble. The tweak itself, well the triad was placed on the
cylindrical object, I did not modify the triad at all and the z axis is
running along the length of the cylindrical object, positive direction is
opposite the direction the parts need to move.
When I have little time I'll try to create the tweaks in the precise order
and see what happens.
Scott
