Point to surface constrain
karl8MYHC
Message 1 of 8
karl8MYHC
Community Visitor
Community Visitor
Hi
I want to mate a bearing to a disc. The idea is to easily drag the disk around  and "simulate" when the bearing moves in and out on the hight difference on the disk. The problem seems to bee that the center axis of the bearing is not related to the disc with a constant angel. Thats why im thinking of doing a point to surface. The problem then is that i cant choose the whole surface, just a part of the surface.
Someone who knows a solution for this?
Replies (7)
Message 2 of 8
admaiora
Hi, there is no point to surface constraint
(here an idea: https://forums.autodesk.com/t5/inventor-ideas/assembly-constraint-mate-point-surface/idi-p/5173383)
You can use the "transitional" constraint (it can be a little unstable)
Or use the Dynamic Simulation enviroment if you want to really simulate that
Admaiora
_____________________________________________________________________________
Message 3 of 8
karl8MYHC
Community Visitor
Community Visitor
Hi
I tried that but i cant select the center point of the bearing when using the "transitional" constrain...
Can i send over the files to you. maybee its easier?
Message 4 of 8
admaiora
Yes, attach the files pack
Admaiora
Message 5 of 8
EdvinTailwind
Note that this Idea is archived and can't be voted on, it will need to be revived (either brought back from the archive  by an admin or posted again).
Message 6 of 8
JDMather
In this image your components appear to be interfering?
How does that work in the real world?
Message 7 of 8
EdvinTailwind
Message 8 of 8
JDMather
@karl8MYHC wrote:
I tried that but i cant select the center point ...
Can i send over the files to you. maybe its easier?
@karl8MYHC
There are a myriad of motion Joints available in Inventor, but you will have to engage in bi-directional communication to get help on learning how to use them...
