Point color and size
WindowND
Message 1 of 10
WindowND
Can anyone help out this old guy out?
Is there a way to change the size an color of the "point" while in sketch mode. Currently it is small and lime green and against some colors it virtually disappears. I end up rotating the model looking for it. Being 60 years old with failing vision doesn't help. Additionally I don't want to change the whole color scheme.
Bill
Replies (9)
Message 2 of 10
JDMather
Tools>Application Options>General tab increase Annotation Scale.
Tools>Application Options>Colors tab select a different color scheme.
Message 3 of 10
mcgyvr
yep..
color scheme editor
http://blogs.rand.com/manufacturing/2009/04/inventomizations-interface-color-schemes.html
Message 4 of 10
WindowND
Changing the scale helps a bit but the point is always thin lime geen cross hairs and although changing schemes helps a little I do not like those schemes. I was hoping to be able to change only the point. Thanks for all the help!
Bill
Message 5 of 10
JDMather
There is one other option, but first -
I need to know the purpose of your points.  What are you using them for?
Message 6 of 10
mcgyvr
Bill
There is no way to ONLY change the point color.. but you can change the color of all "unconstrainted" line/point work in a sketch..
FYI..
These elements are controlled by the color of "Under-Constrain Curve" in the Sketch section of the color scheme editor..
Message 7 of 10
JDMather
Check this method of toggling between Points and Sketch Center Points.
Message 8 of 10
WindowND
I place points on planes to allow me to create holes on uneven surfaces.
Message 9 of 10
JDMather
Did you watch the video above (with sound turned on)?
Does that help?
Message 10 of 10
WindowND
All of the above solutions have helped me immensly, thank you very much. Diagrams & videos work great for this old man.
Thanks to all!
Bill
