Place iLogic Component
joeldavide
joeldavide
Hello dear community,
So i have created an assembly that as parts and iParts inside. This parts and iParts can be changed by modifying the form that shows up.
Yes, this could been done using iAssembly, but i had so much combinations to do (and curiosity to explore iLogic) that i used iLogic instead.
Problem: when using Place iLogic Component i get this error : "This command cannot copy and place a document that contains Tube & Pipe components."
That i don't have.
All components are published in a Custom Content Center. I have attached an example of this Assembly.
Any hints?
Best Regards, Joel
johnsonshiue
Hi! I guess there is some sort of corruption in the top-level assembly. Somehow certain component definition becomes ghosted. The only workaround I can find is to demote all the components to a new assembly and copy the iLogic rules over to the new assembly. Then the warning will go away.
Many thanks!
Software Test Engineer
