Place iLogic Component- Unresolved or Substitute Components
amarinXG8V6
amarinXG8V6
Hi everyone,
I'm getting an error trying to iLogic place a sub-assembly into a parent assembly. See screen shot below. The thing is that I have no unresolved or substitute components in this sub-assembly. I have also tried individually ilogic place components for each of the sub-components in the sub-assembly and they all come in properly when I iLogic place them. There are some virtual parts in the sub-assembly that I'm trying to iLogic place, however I have tried deleting all of the virtual components and doing the same place iLogic component function and I still get the same error. Any thoughts on how I could fix this?
johnsonshiue
Hi! Please expand the Model States folder and see if there is no substitute node. If possible, please share the files here. I can work with the project team to understand this error better.
Many thanks!
Software Test Engineer
amarinXG8V6
@johnsonshiue
Thank you for offering to look at this. The files have been included in the zip folder that is attached.
Thank you,
johnsonshiue
Hi! I cannot seem to reproduce the behavior on 2022.2.2 or 2023. It looks like you are on 2022.0. Please install 2022.2 update followed by 2022.2.2 update.
Many thanks!
amarinXG8V6
Installing the 2022.2.2 update seems to have resolved this issue! Thank you!
