piping analysis via Inventor
I did a pipe routing in AutoCAD Plant 3D and want to do stress and thermal analysis via Inventor. Would you please help me how can I import the piping system to the Inventor in a way that I would be able to mesh it and apply stress and thermal analysis?
I know that I can use the import option when I want to open the DWG file, however, I don't know which conditions will lead to having a suitable format to be used in Inventor.
Thanks.
admaiora
You can't do  athermal analysil in Inventor.
You can do it with Nastran In Cad
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
johnsonshiue
Hi! Matteo is right. Inventor Pro does not have a solution to do that by itself. You need Inventor NASTRAN (as part of Product Design and Manufacturing Collection).
Many thanks!
Software Test Engineer
Thank you @johnsonshiue  and @admaiora ,
I do use Inventor Nastran which is a plug-in in Inventor Pro. My problem is how can I import piping system in a way that I could have a pipe instead of a solid part which is not hollow?
Now, I edit the piping system and make a shell with the amount of a pipe wall thickness and then mesh it and solve it. Is it a correct approach?
I'm wondering is there any way to import an exact piping lay out as what I have in Plant 3D?
Thank you.
johnsonshiue
Hi! I am sorry I am confused. How did you get the pipes? Did you use Inventor Tube&Pipe environment to create it? Or, you got it from other sources?
Many thanks!
Sorry @johnsonshiue ,
I thought you have read my first question.
I generate piping routing by Plant 3D and import it to Inventor to be able to use Inventor Nastran for stress analysis.
The imported piping lay out is a solid instead of pipe (i mean it is not hollow). I have to edit any single part and generate a shell resembling a pipe.
I'm wondering is there any way to have a real pipe when I'm importing the pipe from Plant 3D?
(PS: I do use exporttocad command)
