* -PIPE SUB-ASSEMBLIES MISALIGNED WHEN PUT INTO NEW ASSEMBLY FOR NAVISWORKS
m.domina
Message 1 of 8
m.domina
I designed a process plant with pneumatic piping running all over. Everything looks fine.
I then put the entire plant into a new assembly so I could get the origin to line up with the customers' Navisworks origin. All of the piping is misaligned in this new positioning assembly. I asked out CAD group and they had no idea.
Snip of some of the misaligned pipe in positioning assembly
same area in original assembly where everything seems fine
Replies (7)
Message 2 of 8
JLH_Bigadan
I you are on a subscription try the new Navisworks 2024 version. I had a problem with Navisworks not showing the Inventor Model state correctly. Navisworks 2024 fixed that problem.
Message 3 of 8
CGBenner
@m.domina
In your new assembly, what happens if you Rebuild All?
In the original assembly, is your Master Pipe Run constrained to the origin planes, and all individual pipe runs constrained to the Master Run's origin planes?
Chris Benner
Message 4 of 8
m.domina
My problem is in Inventor. When I take an assembly of pipes and machines and place it into a new assembly, all of the pipes become misaligned.
Message 5 of 8
m.domina
Nothing happens when hitting Rebuild All.
The pipe runs are constrained to themselves with each elbow and stick of pipe having Insert mate and axial constraints to eachother.
When I measure the pipes that look misaligned, they measure in line. So maybe its all graphical and something with my computer?
Message 6 of 8
johnsonshiue
Hi! If possible, please share the files in zip here or send it to me directly johnson.shiue@autodesk.com. I would like to understand the misalignment issue better.
Many thanks!
Software Test Engineer
Message 7 of 8
m.domina
I just shared a Google link with you. It coming from one of my personal emails. File is named "ADM PACK N GO".zip
Message 8 of 8
johnsonshiue
Hi! Many thanks for sharing the file! I am in the process of downloading the 2GB attachment. I will let you know when it is done and you can unshare it.
Thanks again!
