Hello
I have created a pipe routing assembly inside another assembly as I have done many times before. I am quite familiar with this. However this time I would like to create drawings of the individual pipe runs but also show the top level on the drawings as reference.
My initial thought was to create a level of detail of the top level with the piping assembly supressed so that I can place the top level into each of the individual pipe run assemblies. This I thought might get around the placing an assembly within itself issue...
However, in order to edit the piping sub assemblies I need to edit this within the top level assembly as they are now owned by the top level. The problem is, when I try to change the level of detail within the place component options dialog, the level of detail is greyed out so it cannot be changed. I can do this if I open the sub assembly but I am unable to save the file as it is out of context.
I really don't want to created a duplicate of the top level excluding the piping assembly in order to insert within the sub assemblies as I believe this to be counterintuitive and could lead to errors if the top level is ever changed (and the duplicate is not).
Any help would be greatly appreciated
Paul
