Pipe connection. Tube &Pipe Authoring -> ISOGEN export -> ISO drawing
wydawnictwo
Message 1 of 1
wydawnictwo
Hello all,
I very often create welded pipe connections as in the Picture 1. The red pipe that is attached to the main route is simply welded on without the use of any OLET fitting. This red tube is authored as the Branch. What kind of ISOGEN Type and Skey parameters should be used so that such a pipe connection is exported correctly to a pcf file and then after conversion to an ISO drawing the correct connection will be shown in the ISO drawing, as in the Picture 2.
Maybe there is another method to obtain the correct ISO drawing? I hope this is possible in Inventor 🙂
Regards
Fabian
Replies (0)
