Permanently disable visualization dwf when checking in using Task Scheduler
RStancescu
RStancescu
Hello all,
When I check in multiple Inventor files using Autodesk task scheduler, the "create visualization attachment" is checked by default and dwf's are automatically created, see attached. Is there a way to permanently disable it? I don't need a mass create dwfs process so I need the default to be off.
In Vault I already turned off creation of dwf files (Tools / Settings / Vis Attachments / Define - not enable.
Thank you for your help.
radu
kelly.young has embedded your image for clarity.
rachel_li
Hello @RStancescu
This is not supported in Task Scheduler.  The option is not remembered and cannot permanently disable for now. Would you mind submitting the request to Inventor Ideas?
Best Regards,
Rachel
Rachel Li
Software QA Engineer
Autodesk, Inc.
RStancescu
Sure, I will do that.
Is there a registry that I can alter to switch the default?
Thank you
radu
RStancescu
