PDF plotting issue.
PDF plotting issue.
bwang-tecoustics
PDF plotting issue.
bwang-tecoustics
When I plot a drawing to PDF, the dimensions are shown as vector elements in the PDF but the view are plaotted as image. Some details are lost due to this problem. Does anyone know the reason why this happens and how to fix it?
See picture below, the text are fine when zoomed in, but the drawing showes like dots.
The drawing views are probably set to Raster View Only. If there is a light green corner border around the drawing view, it is a raster view.
Right click on the view and select Make View Precise from the menu.
When placing drawings view you can select whether to place them as precise views or raster views.
blair
Also change the PDF settings from "Standard" to "High Quality" in the Output settings.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
bwang-tecoustics
Thanks for the replies. It seems there were are windows updating in the way which blockes the PDF plotting setting. After I shut down my computer and restart, everything goes well. Thanks again.
