Good morning all! This time I'm having an issue with PDF-EXPORT. No export, no pdf.
Still stuck into Inventor 2017, but now re-installed in brand-new power workstation.
System Windows 10 Enterprise, version 21H2, pack 19044.1826. In HP zBook 32G RAM
Issue concerns to DRAWING (2D output) environment. When opening any drawing, the following errmsg appears:
Then, by hitting the PDF-Export tab (File/Export/PDF) comes the "Save As"-tab as usual. And that's all, no more go. "Options" tab is not greyed, but nothing happens when pressed. And by "Save" no pdf, nothing.
And no, not the obvious. C:\Program Files\Autodesk\Inventor 2017\Bin does have that very DWFOut.dll ...
Any ideas? Tips, tricks? Anyone familiar with that kind of issue? Something to do with system setup (for drawings)?
Still having even my (rather dated) old PC running. No problems, pdf-export works fine, never failed. Both workstations share the same templates, working with the very same models/drawings/etc. Now, doing my job still with the old PC. Just because the principal output format shall be pdf. Pretty annoying, I'd say...
