Pattern part along a path assembly
I'm trying to pattern a cablechain used for a machine. I've created a model including both mounting brackets for the chain and the part that the chain consists of. The pattern should look like a "candy cane" shape and the total lenght of the chain should be approximatley 2425 mm. It's not the most important part, i would just like it to look good in the model. I've used the tecnique where i create a part that represents the path i want it to have and then use feature pattern in the assembly model for the part. It's a tecnique i've used successfully before with similar challenges but i just cant seem to get this one right and now i think i've spent to much time thinking about this and i would appreciate if someone else could take a look if this is possilbe to solve 😅
Thank you in advance!
// Joakim
