PATTERN AN ELEMENT IN SKETCH
AnthonyHarris90842
AnthonyHarris90842
I am in sketch environment and doing a circular pattern of the small circle but the preview is in black and I am using a black background so when I am in wireframe I cant see the pattern.
Can I change the colour or does Autodesk have to change it.
See image below
Replies (14)
talha.tufan523TD
if i didn't get it wrong you are asking this settings?
AnthonyHarris90842
I checked through the colour scheme settings but couldn't find anything for pattern preview
talha.tufan523TD
@AnthonyHarris90842  I checked but couldn't find it. and even in regedit I visited the place in the photo but got lost. Sorry I can't help but I guess this option is not available in inventor. The challenge is not over yet, if I find it, I will share it.
johnsonshiue
Hi Folks,
I don't think there is an option to change the sketch preview color. The quickest thing to do is to make the part transparent temporarily. Right-click on the part in the assembly -> check "Transparent."
Many thanks!
Software Test Engineer
AnthonyHarris90842
Surely it should be changed.
Of all colours why black.
We always have to work around silly stupid things that are so easy to fix.
AnthonyHarris90842
Hi Johnson
Has anything been done about this black array colour yet?
Mario.VanWiechen
Easy answer is to not use patterns in the sketch environment, make them features, much more stable and easier to edit.
Sketch driven patterns though work very well
JDMather
@AnthonyHarris90842
As per @Mario.VanWiechen why oh why are you using sketch patterns rather than the more computationally efficient, functionality more powerful Feature Pattern?
SBix26
What color scheme are you using, and what version of Inventor?  In my Inventor 2024, using the stock Wonderland color scheme, this is the sketch pattern preview that I see:
Sam B
Inventor Pro 2024.1 | Windows 10 Home 22H2
BDCollett
I get a preview in white also with dark mode and all other themes with Inventor 2024.
I do wish the answers on here when a feature is not doing what someone wants is to tell them not to use it at all.
There are times you still need patterns in a sketch, you might not even turn them into a feature. Not using it is irrelevant to the problem.
johnsonshiue
Hi! I have trouble reproducing the behavior. I need to know what exact color scheme is used and the preview is set to black.
Many thanks!
AnthonyHarris90842
Hi Johnson
I attached a copy of my applications options file which should have the settings for the colour scheme editor.
Use copy of high contrast and then you will see you should get the black preview like I do.
When I change to the other colour schemes then its ok but I cant which setting controls the preview colour
johnsonshiue
Hi Anthony,
Many thanks for sharing the App Options. This is indeed the Color Scheme related. It seems that "3D Thick Line" option can control the behavior. Go to Tools -> App Options -> Colors -> Color Scheme Editor -> select the color scheme -> Customize Schemes -> Sketch -> find "3D Thick Line" and change its value to 2.
After that, the sketch pattern preview will behave normally.
Thanks again!
AnthonyHarris90842
Hi Johnson
Thank you very much. that fixed it.
What an obscure place to hide the preview colour .
It should just be named preview or something like that and you choose a colour like everything else, not a number.
I thought those number relate to line thickness.
Once again thank you for always being so helpful
