Pattern a component in an assembly at irregular intervals
Message 1 of 10
Am I missing the function that will allow me to pattern an original (seed) part at several different distances?
It seems this should be a simple thing to do?
J.
Clarification; I have four parts arranged like I want them in an assembly that I would like to pattern 5 total times in one linear direction without having to place the four parts five separate times (that would be a pain). One at 54" from the original, 22" from the first copy, 24" from the second copy and 41" from the third copy. Is this possible or is there a way to do this that I'm missing?
Replies (9)
Message 2 of 10
kennyj
Hello @Anonymous!
To clarify; did you mean several patterns at the same time or to have the option of changing pattern spacing between several choices?
For the first option, I'm not aware of a way since the pattern consumes the seed part.
For the second option, you can create parameters for the variable distances, then use those parameters in the pattern settings to be able to switch between.
Hope that helps,
Kenny
Message 3 of 10
mcgyvr
oops..duplicate post
Message 4 of 10
mcgyvr
Is there such thing as an "irregular pattern"? Smiley Wink...
You can suppress specific instances of a pattern if needed..
Message 5 of 10
Mark.Lancaster
@Anonymous
Not sure if this will help or not..  But you could make an irregular pattern as a part and then pattern the component in the assembly using that reference.
Mark Lancaster
Message 6 of 10
What you sent applies to a feature in a part. I want to irregular pattern a part(s) in an assembly.
Message 7 of 10
Mark.Lancaster
What did I say in my posting.. You would have to create a part with that irregular pattern and then use that pattern as a reference in the assembly.  Meaning that patterned part would need to be placed into the assembly..  You can set that part as a reference BOM so it doesn't appear in any BOM.
Mark Lancaster
Message 8 of 10
TheCADWhisperer
The Feature Pattern is selected in the Component Pattern dialog.
Attach your assembly here and end all doubt.
Message 9 of 10
Long way round... other software allows reuse of seed part.
Message 10 of 10
filippo.toniello
Using a part with scketched pattern is a solution but it is a partial solution.
In assembly mode other cads permit to use this feature without operating on a part (creo use also tables in pattern)
i think it is a "conditio sine qua non" for a modern cad application
