Patter Component & Mirror Component 2016.
Nice work on the Midplane option in the Pattern Component tool, finally.
Great to see the Mirror Component tool is still a useless piece of crap!
Regards.
ChrisMitchell01
Hi Paul,
Good to hear that you like the midplane option.
Can you elaborate on what crap actually means ? Is there some specific crap you want us to fix, or is the crap mentioned in the existing IdeaStation posts, the crap you refer to ?
http://forums.autodesk.com/t5/forums/searchpage/tab/message?location=board%3Av1232&phrase=mirror+com...
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Apologies,
In Australia we call garbage i.e. trash “crap” 😉
The fact that a mirrored component simply floats in space with no constraints to me renders the tool absolutely useless. Grounding the part after mirroring is not ideal, as if an assembly length, width etc changes the mirrored part stays in its grounded position. Useless!
As someone in the IdeaStation posts eluded to; Solidworks and ProE solved this problem years ago.
Regards.
ChrisMitchell01
I know; I was just being facetious - you could likely change the spelling of that & subsequently relate that to the true definition of crap Smiley Happy
Yes - now (unfortunately) understood.
-Chris
Chris Mitchell
Autodesk, Inc.
