Parts not loading/slow loading but assembly run fine
LBE-01
Observer Observer
LBE-01
Observer
Observer
Parts not loading/slow loading but assembly run fine. there's multiple single parts in this assembly including a fairly large mesh but it run fines loads into drawings fine, as soon as i try to open the single parts so that they can go into drawings it just loads only using like 8% of CPU and ram that all it douse. all part where drawn from the assembly.
there is lots of hexagons 30mm.
the odd part is i can find & place the parts in drawings with very few issues.
but they will need to end up as dxfs so i need the parts to do that.
  • Help
CGBenner
@LBE-01
Hello, and welcome to the forum.  Can you give us a little more information please?  What version of Inventor are you using, and what are the specs of the computer you are working on?  Would you be able to share the files here in this forum for others to look at?  Thanks, and good luck!
Chris Benner
LBE-01
Observer
Observer
The version is Inventor 2024.3.
unfortunately i am unable to share file due to data sharing  restrictions.
 CPU:13th GEN INTEL CORE I7-13700K (base speed 3.4GHz)
RAM: 128GB 3200MT/s
GPU: NVIDIA GeForce RTX 3060 TI
johnsonshiue
Hi! I suspect this could be graphics related. If possible, please share the files in zip with me directly at johnson.shiue@autodesk.com. I would like to understand the intermittent performance issue better.
Many thanks!
Software Test Engineer
