Parts List Units
Parts List Units
Parts List Units
I've created two iParts and published them to Content Center.
When I bring them into an assembly, then into a drawing, and create a parts list, one of the parts gives me a (") suffix (which is what I want,) one does not.
Where do I change this? I'm assuming I'll have to delete and re-publish the parts back up to Content Center when I've made this change.
Here is a screenshot of my parts list - I would like them both to appear like the first row does (the 1/2" plate part.)
Thanks!
Ben
Inventor 2016
salariua
Check the Export Parameter Formatting and make sure units are on (although this would come as "in"). Compare on both your parts.
You can also try to edit you table (is that a general table?). right click on the column and choose Format Column, check settings there as well.
And the most obvious, edit the family and add your units there (compare both families)
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
