Parts List Style missing from Format dropdown.
andrewdroth
Advisor Advisor
Message 1 of 12
andrewdroth
I made a new parts list style in a drawing template, and saved it to the styles library.
Now when I create a drawing from that template I don't see the style in the format dropdown.
If I do a save as with the template file it exists as shown.
But this is the list I see when creating a drawing from the template file.
Here in the Styles Editor you can see it has been saved to the Library.
I've been using Inventor for a long time, but these styles are the least intuitive part of the program.
It seems like every time I have to deal with them, I'll google forum posts, and find my own post from years ago. LOL. Maybe It's just my bad memory.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Replies (11)
Message 2 of 12
Frederick_Law
Styles under ----------- are not in current Standard.
Hence Style Library won't load it into new files.
Try stick with one Standard.
Message 3 of 12
andrewdroth
Ah, it's this right?
It's confusing that the standard shows up in the local list of the template file, but not in a file created from a template.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 4 of 12
Frederick_Law
Not in use because it's not in current Standard.
Expand the Standard on top left and see all Standards.
Click on your Standard and select Available Styles on the right.
Message 5 of 12
andrewdroth
What do you mean by that? Because I use different standards for different clients, based on what they want to see. Surely that is the proper way to handle that requirement?
I guess it's my misunderstanding of "in-use", because I can add the parts list style to the template and sync with the library, I can also save the standard to the library at that point, but it doesn't make that style "in-use".
The only way I could figure out how to make it "in-use" was to add it to an object default for the standard, but that doesn't seem right. I should be able to have styles available that are not set to standard.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 6 of 12
Frederick_Law
You can have one Standard with different Object Defaults.
Add the Style to Available in Current Standard should work.
I never used multiple Standards, so not sure how IV will behave.
I don't have not used Style also.
I do know.
If Style Library has same Standard/Styles as Template, IV will not save them in new file.
Looks like it won't save not used Styles also.
Gotta go.  Will be back tomorrow.
Message 7 of 12
pcrawley
@andrewdroth - I think the bit you're missing is making the Parts List Style available to the Standard(s) you are working with.
In the Styles Editor, you can see the active Style (see "1" in the image below):
If you switch the filter (top right) to "All Styles" and look at the "Available Styles" you can now tick the Parts Lists Styles you want available to your active Standard.
To make the parts list style available to another standard, activate the standard (1) and tick the styles you need.
Peter
Message 8 of 12
johnsonshiue
Hi Andrew,
On of what Peter and Frederick already mentioned, the issue here is that the style in the standard is not used by any other setting or object in the template. The standard is standalone by itself. Such standard in the template will be removed on starting a new file.
Many thanks!
Software Test Engineer
Message 9 of 12
Frederick_Law
One way to "cheat" the system.
Keep all your standards in template.
NOT in Style Library.
IV will not delete them on new file.
Files will be larger because of all the standards in it.
Anyone has the file will have all the Standard Styles.
ie, they know all your customers.
You'll need to work out how to handle different Standard for different customer.
1 Standard, different Object Defaults, 1 Template.
Different Standards in different Templates.
Any other combinations.
Message 10 of 12
andrewdroth
Yep, this is what I was missing. I figure that because I had copied the style from the library to the local document, that it would be associated with the current standard. Not that easy.
It makes sense that you would get to pick and choose which style goes with what standard, but I'm not sure I've ever done that before.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 11 of 12
andrewdroth
Is that true? It seems to me that the object defaults are tied to the Standards?
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 12 of 12
Frederick_Law
It may not make is easier .....
You can pick Object Default in Standard.
Need to change it in the file.
Standard in Style Library will have "Object Default 1".
Templates can use "Object Default 2" or other.
Maybe Standard for each customer easier.
