Inventor Forum
Parts list and revision tables
4 REPLIES 4
ZFerrarini
202 Views, 4 Replies
I am using Inventor 2023.
I created some templates with a new parts list and a new revision table as we like it here.
They are working, but I am not able to set them as a default: how do I do that?
Also, in the drawing, I see more styles than what I see in the style editor.
I already did the purge + update, but they are still there: how can I remove them?
Thank you in advance.
4 REPLIES 4
johnsonshiue
in reply to: ZFerrarini
Hi! You will need to go to Object Defaults. Go to Styles Editor -> select the active standard -> go to Object Defaults tab on the right. The change will need to be saved in the drawing file. And also save back to the Styles Library.
Many thanks!
Software Test Engineer
ZFerrarini
in reply to: johnsonshiue
Not sure where that Object Defaults is. Can you send a screen shot please?
Hi @ZFerrarini In picture you send, one item above parts list (highlighted in yellow) is Object Defaults.
Ok, I missed it. Thank you.
