Partial chamfer bug?
sschulteH6WZ3
Message 1 of 8
sschulteH6WZ3
Has any one else had this issue with partial chamfer? The edge that needs to be chamfered is exactly 125mm long. I have the partial chamfer set to 125 mm, yet the chamfer continues past the silver marker ball all the way down the part? In the meantime, I will set it to 124.9999 and just do a cut extrude to get rid of the wall. See JPEG and attached part.
Replies (7)
Message 2 of 8
johnsonshiue
Hi! The behavior does look defective to me. Could you share the part here? I would like to work with the project team to understand the behavior better.
Many thanks!
Software Test Engineer
Message 3 of 8
sschulteH6WZ3
I tried to attach the file but I must have done something wrong. I will try again. It is not letting me or I am doing it wrong.
Message 4 of 8
sschulteH6WZ3
This thing wont let me post if I have the .Ipt file attached. It is very flaky.
Message 5 of 8
Hochenauer
Hi, you can send the part directly to Johnson using his work email address, or share it with me:
[email protected]
Johnson Shiue <[email protected]>
if there are security problems, zipping the file likely will solve that.
Gerald
Gerald Hochenauer
Senior Principal Engineer, Inventor
Autodesk, Inc.
Message 6 of 8
sschulteH6WZ3
It has been sent.
Message 7 of 8
Hochenauer
Johnson and I had a short discussion and decided to involve the team working on the modelling kernel. We will update you with what they find.
Kind regards,
Gerald
Gerald Hochenauer
Autodesk, Inc.
Message 8 of 8
IgorMir
You are not the only one. I am experiencing the same difficulties with attaching files. My guess is - we are going through another wave of "improvements"
Cheers,
Igor.
Web: www.meqc.com.au
