Inventor Forum
Part will not extrude
2 REPLIES 2
Vagulus
429 Views, 2 Replies
This part refuses to extrude (except for the two lower circles).  Each of the separate areas has to be extrudable separately (and all together).  I've looked for lines not joined (tho' my eyesight is not what it was when I was 15☹️).  The sketch is fully constrained.
What am I missing?
Thanks.
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
2 REPLIES 2
JDMather
in reply to: Vagulus
Did you use Mirror in the sketch?
I recommend that you not do that in versions of Inventor before 2020.
You can create the lines and add Symmetric constraint, but do not use Mirror.
Vagulus
in reply to: JDMather
Thanks JD.
I keep forgetting: "Mirror objects, not sketches!" 😖
Albert Einstein
