Part Sketch Dimensioning Prompt not Working
simon.brammer
Observer Observer
simon.brammer
Observer
Observer
Hi all
when dimensioning lines, circles ect in a sketch normally when you dimension the object it automatically allows you to edit the dimension first before finishing the command. But now for some reason when i add a dimension to a line it finishes the command with what ever value the line was drawn at and i have to now double click on the dimension to change  the value....
can someone please help by telling me which box to tick to allow value entry before exiting a dimension contraint in sketch mode
JDMather
Tools>Application Options>Sketch tab - Settings, Dimension...
mcgyvr
With the dimension command active right click and make sure "edit dimension" is checked..
johnsonshiue
Hi! Yes, there is an option to control it. Besides the one shown by Brian (right-click context menu on creating a sketch dimension), there is a setting in Tools -> App Options -> Sketch -> Constraint Settings -> "Edit dimension when created."
Many thanks!
Software Test Engineer
simon.brammer
Observer
Observer
Hi Everyone
thanks for the quick responses. This solved the problem!
Sometimes you question your own logic wondering if it has always been like this  !
regards
Simon
Can't understand how this switches itself off now and then but I always forget where this instruction is buried - and I have to say DOH! every time I find it because it was there all the time...😂
Many thanks
Simple things can be overlooked when you have forgotten what you're looking for...
JDMather
@Anonymous wrote:
Can't understand how this switches itself off now and then ...
See Message #3 - you can accidently do it when using right mouse button gestures.
Probably aiming for End Sketch and instead turned of dimension option.
