Announcements
part file,,, It looks far.
dane-kwon
dane-kwon
HI
Made in different 3d program file open the inventor
view is so far far far  šŸ˜ž
Any good ideas ?
check plz
Replies (8)
CCarreiras
Hi!
I can't find the reason why this occurs.
Sometimes this is due to a "lost" sketch point or other element forgotten far from the main geometry, but in this case, i can't find some "lost" element.
I believe this is happening due the translation between cad softwares.
You can set a new Home position:
Zoom the part as you need as Home position
RMB the cube and select fixed view.
To access to this view, click Home, instead of using zoom all.
CCarreiras
TheCADWhisperer
@dane-kwon
I am not at my Inventor machine, but does the import pass quality check?
Right click on the body in the browser and select Repair.
If that doesnā€™t work I would go to Construction Environment (normally hidden by default), Unstitch, run another Quality Check, Stitch, run another Quality Check and Promote (once everything is repaired).
I assume the geometry is at the Origin.
@CCarreiras has probably already done all of this and found nothing obvious.
SBix26
The file you attached is Inventor 2017 format, so that's what I used.
The part is centered on the origin and all faces and bodies passed quality check.  When I followed @TheCADWhisperer's advice and unstitched and then stitched back again, the problem disappeared.
Update: the repaired file is attached (2017 format).
Sam B
Inventor Pro 2023.2.1 | Windows 10 Home 22H2
johnsonshiue
Hi! I am not sure I see the problem. The graphics does look choppy on open. But, it clears out when I rotate the view.  The body checks clean. I don't see any issue. This could be a graphics artifact. Try Manage -> Rebuild All. Does it work better now?
Please make sure all critical Windows updates are installed and the graphics driver is updated.
Many thanks!
Software Test Engineer
dane-kwon
HI
thanks !
this problem is mouse wheel button double click and view cube click
zoom is very far away ...
dane-kwon
HI
thanks a lot
i don't know unsitch
can you give me  details?
dane-kwon
HI
thanks a lot
SBix26
In Application Options > Part, select Enable Construction Environment (you may need to re-start Inventor after this).
In the part, click on the Copy Object tool (3D Model > Modify panel), select the part, then set the Output to Create New > Group:
This creates a new group in the Construction folder, which you will now see in the Browser.
  • Double click on the Construction folder, and you will now be editing the surface body that was copied there in the previous step
  • Right click on the original imported body in the browser and delete it
  • Start the Unstitch tool, window select the entire part and click Apply, then Done (your part is now 239 separate surfaces)
  • Do the same with the Stitch tool, selecting all 239 faces, Apply, Done (your part is now back to a single solid)
  • Right click on Solid 1 and select Copy Object; the default Output will be Create New > Solid, which is what you want; OK to finish
  • Exit the Construction environment
  • You can then optionally delete the Construction folder which should now be empty
Hope that helps,
Sam B
