Part design in assembly environment
halilibrahimsarsmaz
Message 1 of 17
halilibrahimsarsmaz
I want to design a part in the assembly environment in Inventor. When I add a new part, I want to take references from the corners of a part that already exists in the assembly. While doing this, I don’t want to use the Project Geometry command. I used to work with this feature before. But now, I don’t know which options I need to activate. Thank you.
Best regards.
Replies (16)
Message 2 of 17
CCarreiras
Hi!
You want to take references, but you don't want to project geometry?!
So, How do you want to do?
Tip: DERIVE the reference part to the new part, it's also an option.
CCarreiras
Message 3 of 17
halilibrahimsarsmaz
Hello, when I enter the sketch and want to make a drawing as shown in the image, I want it to automatically snap to the corner of the part, just like in the part environmen
Message 4 of 17
kacper.suchomski
This automatic snap is actually automatic projection.
Kacper Suchomski
Message 5 of 17
halilibrahim_sarsmaz8PF35
Previously, it only automatically projected the geometry of the contacting area, not the entire face where I opened the sketch. A similar feature exists in all CAD software
Message 6 of 17
It depends on the program settings and what you click while working.
Kacper Suchomski
Message 7 of 17
steveh5
Not quite following the thought here but agree w/ all "Project Geometry" is what should be used when designing a part in an assembly. Might have to do more w/ "ADAPTIVE"?
If you would like to project but not make it adaptive?
One way of doing this is ....While in the part sketch choose the "Project Geometry" and while pick the objects would like to project, hold down the "CTRL" button. This projects the the geometry but does not make the part adaptive.
HTH,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Message 8 of 17
Thank you for the answers. What I exactly need is this: just like when we open a sketch on a part in the part environment and can snap to the corners, I also want to be able to snap in the same way when I add a new part. However, I don’t want to use Project Geometry for this. This feature used to exist, but I don’t know which settings need to be enabled
Message 9 of 17
CGBenner
Hello.  I think what is tripping me up, and maybe others trying to help, is the "snap to the corners".  In a Part sketch in Part environment.. what corners are you referring to?  Corners of existing geometry in the part sketch?  Thanks!
Can you tell us what version you are using?
Chris Benner
Message 10 of 17
CCarreiras
HI!
As @CGBenner , I also don't understand what's your goal but...
Maybe it's a long shot, but enable this and try again...
Or maybe you need to use Project Cut Edges to get all the edges at once, instead of picking Project Edges one by one...
CCarreiras
Message 11 of 17
SharkDesign
Use Carlos app option above to stop the automatic projection of the face that you mentioned.
You cannot snap sketches to geometry without projecting, this is just how Inventor works. I assume you are more familiar with Solidworks which does not do this?
  Inventor Certified Professional
Message 12 of 17
halilibrahimsarsmaz
Hello, I think I’m not explaining the problem clearly. I haven’t used Inventor for about 2 years, but I’m quite sure this option existed before. My style is usually designing directly in the assembly environment without opening any separate part files. Once I figure out the solution, I’ll add an update under the topic. Thank you very much for your interest and support, friends.
Message 13 of 17
kacper.suchomski
No, Inventor never worked like that.
You can enable snap-to-grid mode  in the sketch, which is only a seeming tool, but it gives beginners a sense of control.
Reference can be achieved through:
  1. projection sketch geometry and adaptivity
  2. copying geometry (model)
  3. linking parameters (using various methods)
  4. derived components
  5. constraints / joints
Kacper Suchomski
Message 14 of 17
dan_inv09
I think that what the problem is that in a part you sketch to the corners and although the points were being projected it is hard to tell, but in the assembly environment it is always projecting the entire edge and doesn't seem to allow you to grab just the point.
You could probably change the appearance of the projected lines so that they do not clutter up your sketches (I don't know if that is a setting - that would be nice). I think you can delete the rest of the projected line after you have something constrained to the endpoint that you need.
Message 15 of 17
swalton
Projected geometry can be set to construction in application options.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 16 of 17
johnsonshiue
Hi! I could be wrong but I believe @halilibrahimsarsmaz is looking for way to insert a new part on top of an existing part. The workflow is like this. Create -> Create In-Place Component -> Ok -> pick the XY plane of the existing part.
Many thanks!
Software Test Engineer
Message 17 of 17
CGBenner
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
