Part/Assembly Visibility
should add a commend to switch invisible part on in assembly. That will avoid lot of time of browser searching. (Sorry for my English)
mcgyvr
This functionality already exists..
Just right click on the current/active view rep and select "all visible"
That will turn all invisible parts back to visible again..
In 2017 there is also a function to make a part "transparent" instead of invisible..
That allows you to see behind it but to be able to quickly turn it back to regular again..
karthur1
Not sure exactly what they are asking for.... maybe there is a part that has been turned off.  In order to turn on the visibility of all parts, activate the "Master" View Representation.
johnsonshiue
Hi Kirk,
I guess the user is probably asking for "Select Invisible Only" command in Selection Priority dropdown. Currently, there is only "Select Visible Only" command.
Many thanks!
Software Test Engineer
mcgyvr
@johnsonshiue wrote:
Hi Kirk,
Many thanks!
@johnsonshiue Johnson, This was an older post and some moderator "moved it to the ideastation" or so the email that I got about it said so..
Maybe they moved it to the wrong place.. Or it just gets all marked as "new" when they tried to move it there..
The email I got..
The post Part/Assembly Visibility was moved by Discussion_Admin.
Reason:
We moved this idea to the fourm board
Explanation:
