Parametric Assembly/Design
eray_gunaydin
eray_gunaydin
Is it possible to make parametric assembly in Inventor? I don't speak about parametric parts.
For ex. i want to make a special conveyor by myself, i don't want to take it from factory files.
I want to change it with special lengths, width and heights. Is it possible?
Thanks.
johnsonshiue
Hi! Inventor is a feature-based parametric solid modeling CAD system. All modeling commands in part and assembly are parameter-driven.
I think what you are asking if you can drive component changes from top-level assembly. The answer is absolutely yes. It can be done in various ways (iLogic, Derive, Link Parameters, and Adaptive). Please share an example so forum experts can show you the best workflow to achieve your goal.
Many thanks!
Software Test Engineer
