Parameters order
Parameters order
ZFerrarini
Parameters order
ZFerrarini
I added some parameters in the menu, but looks like I can't reorder them. The order I wrote them is the order I get.
Is there a way to move them as I want?
Thank you in advance.
Accepted solutions (3)
Alexander_Chernikov
I think it's impossible.
You can click the parameter name column header to sort them alphabetically.
However, the next time you open the parameters window, they will revert to the order they were created in.
If you use the parameter list when assigning dimensions, it will always be sorted alphabetically.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
kacper.suchomski
Hi
I don't know of a way to do this.
In version 2026, you can create your own parameter group that will collect parameters in the order they were added to it.
Kacper Suchomski
johnsonshiue
Hi! You may sort the Parameter Names alphabetically by clicking the header in the dialog. But you cannot reorder the items.
Many thanks!
Software Test Engineer
