Parameter unit errors
a2059514
a2059514
I have 2 parameters:
  • T1 = 60 ul
  • Dp1 = 250 mm
I'm trying to calculate another parameter (in mm) called Pd. This parameter is calculated T1 / Dp1. I've been trying to modify (in the equation) the types of variables so that it doesn't have an error. Whats the correct way of writing T1 / Dp1 with units so that my parameter PD (mm) doesn't end with an error.
johnsonshiue
Hi! There are multiple ways to do that. The key is to make sure the units are the same on both side of the equal sign.
Option 1: ( T1 * 1 mm / Dp1 ) * 1 mm
Option 2: T1 / ( Dp1 / 1 mm ) * 1 mm
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
a2059514
Thanks!
