Hi Gang,
I have created a part that I want to make an iPart. The part is a electrical component. The parts all have the same size and physical configuration. What I want to do is add a text field to the top of the part that I can control via a table. That way when I insert the component into an assembly I can be sure that the part number on the part is associated with that particular dash number.
Where it says "TEST" I want to be able to assign the text to a field in the table of the part and be able to adjust that text in the table to change with each different part.
I hope all this makes sense. I have attached the IPT file.
Keith
Link copied
