parallel spline / involute spline connection generator, retrieve model annotations
jaimin.ja.3
jaimin.ja.3
I have design Shaft and use parallel spline connection generator for the splines
Now in the drafting i want to retrieve model annotations of the spline data is that possible ?
johnsonshiue
Hi! The quick answer is no. The data is stored in the shaft in a format, not understood by the drawing, only accessible by the Shaft Generator. You will need to get the data from the generator and paste it to an Excel spreadsheet. Create a general table from the spreadsheet or insert it directly to the drawing.
Many thanks!
Software Test Engineer
Alexander_Chernikov
As we found out (with @Andrii_Humeniuk  , see https://forums.autodesk.com/t5/product-design-manufacturing/inventor-osoblivosti-oformlennya-kreslen... ), information about Spline Connections is stored in the assembly in the "Occurrences" branch: oAssDoc.ComponentDefinition.Occurrences(i).AttributeSets(1).Item(2).Value
It can be obtained using iLogic/VBA, taking into account that the “Value” parameter stores a link to the standard code and to the standard data table in
C:\Users\Public\Documents\Autodesk\Inventor 202X\Design Data\Design Accelerator\Tables\Splines*\namestd.xml
namely in "SplineType" - Standard Code in the form, for example, for ISO 14
<Table InternalName="605A0796-2412-4aa9-81E0-E36325D0AE4F">, and in “Spline” – the line number in the list of possible spline parameters of this standard.
Then you can either rename this element in the assembly or part and/or add a user parameter, which you can then use to call out symbols both in the model and in the drawing.
Of course, the best option would be to create a tool like "Hole and Thread" for the drawing environment that allows you to automatically apply the designation.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
I think, the problem is solved.
See:
https://forums.autodesk.com/t5/inventor-forum/symbols-for-designating-straight-and-involute-splines/...
Facebook | LinkedIn
