Parallel edges constraint in assembly
LiveLover
LiveLover
Hello!
I need to constraint two parts so that a specific edge of the firs part to be parallel with a specific edge of the second part.parallel edges constraint question for forum.png
this question looks the same https://forums.autodesk.com/t5/inventor-forum/parallel-constraint-in-assembly/m-p/3276711#M421873
But I can not select edge for angle constraint.
Help please.
Regards
JDMather
This is a curve, not a straight line.
Sketch1 is not fully defined.
Sketch3 is not fully defined.
Sketch4 indicates an unresolved issue.
Sketch6 is not fully defined.
johnsonshiue
Hi! Like JD found out, the edge is not straight. You can create a workaxis by picking the end points of the edge. Then Angular Constraint should work.
Many thanks!
Software Test Engineer
LiveLover
Thank you JD Mather!
