I performed the below steps.
1. Copied folder: Standard 36w 24d 30h to folder, TEST.
2. Within Inventor 2020 open drawing file Housing 36w 24d 30h. Where that file is located in folder TEST.
3. Select File/Save As/Pack and Go
4. Within Pack and Go window browse Destination Folder/Make New Folder. DESTINATION is the name of the new folder.
5. Within Pack and Go window: Options - Copy to Single Path, Collect Work Groups
6. Select Search Now
7. Select Start
8. Close drawing file.
9. Open drawing Housing 36w 24d 30h within folder DESTINATION.
10.Open assembly Housing 36w 24d 30h as associated with view drawing in step 9.
11.Right click part in assembly, select iProperties. The location of the file is not folder TEST and it is not folder DESTINATION. The part's location is the original as noted in step 1.
I expected a Pack and Go would create assemblies with parts referenced within folder DESTINATION.
Is it expected that I use Design Assistant with the drawing in folder DESTINATION and associate the assembly and the assembly's components to components with folder DESTINATION?
