Pack and Go crashing on search
I'm trying to do a pack and go on a large assembly and its crashing as soon as I try to search for parts. I'm not too sure what could be causing this so wondered if anyone has had a similar issue. I have been working out of a onedrive folder, but everything is set to "keep on this device" so all the files should technically exist on the C:// drive.
I'm using Inventor Professional 2020
Thanks in advance for your help,
Matt
johnsonshiue
Hi! Please make sure all critical Windows updates are installed. Also install 2020.4 update followed by 2020.4.1 update. Clean up %temp%. Lastly, make sure the search path is less than 256 characters.
Many thanks!
Software Test Engineer
Hi Johnson, installing the updates fixed the issue straight away, thank you!
