Inventor Forum
Override Mass in batch
2 REPLIES 2
hugo.trepanier
575 Views, 2 Replies
We currently convert more than 10,000 .sldprt file to .ipt. This is an old library of part from SW. All is done by Autodesk Inventor Task scheduler. But Now we need to manually override the Mass with the custom iproperty. Any tool to do this? Inventor BOM could be an usefull tool but it can't override MASS, we absolutely need to open 10,000 part one by one to doing this :(.  Will the the only way to do this be a macro to run in batch? If a macro is available it could be useful.
Hugo Trepanier
Autodesk MSD Application Specialist
Labels (3)
2 REPLIES 2
ckeveryga
in reply to: hugo.trepanier
This rule will update the mass for every part in an assembly and subassemblies.
Class ThisRule
Dim oAsmDoc As Document
Public Sub Main()
	oAsmDoc = ThisApplication.ActiveDocument
	If oAsmDoc.DocumentType  <> DocumentTypeEnum.kAssemblyDocumentObject Then
		Return
	End If
	Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences)
	MessageBox.Show("All weights updated.", "iLogic")
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences)
    Dim oOcc As ComponentOccurrence
	Dim dblMass As Double
	Dim strMassProp As String
	For Each oOcc In Occurrences
		oDocType = oOcc.DefinitionDocumentType
		Select Case oDocType
		Case kAssemblyDocumentObject
			Call TraverseAssembly(oOcc.SubOccurrences)
		Case kPartDocumentObject
			Dim oCustomPropSet As PropertySet
			oCustomPropSet = oOcc.Definition.Document.PropertySets("Inventor User Defined Properties")
			'Check for/create property
			Try
				strMassProp = oCustomPropSet.Item("MASSE").Value
				oOcc.MassProperties.Mass = Convert.ToDouble(strMassProp) / 2.20462 'convert to lbs
			Catch ex As Exception
				MessageBox.Show("No MASSE property.", oOcc.Definition.Document.displayname)
			End Try
		End Select
	Next
End Sub
End Class
 Warning: if the MASSE property is not in the part, a message box will show up! (to remove, comment the message box in the catch)
Hope this works for you.
hugo.trepanier
in reply to: ckeveryga
Thanks you so much for your help!!
All works fine and simply create a dummy assembly with all my 10,000 files to proceed! 🙂
Hugo Trepanier
