What is the best practice for creating overmolded cables in Inventor Cable & Harness environment? In my case, these cables are purchased already overmolded and may terminate in a power plug, sealed electro-mechanical component, connector, etc. It seems I will have to create the part and place a number of pins hidden within the part for the other end of the cable/wires to connect. This both feels clunky and does not transfer well to a nailboard view.
I'm really only interested in demonstrating where to land the flying leads on the other end of the cable...
I appreciate any insight/ideas.
Cable/Harness leaves A LOT to be desired though as its not used by enough to justify new features/functionality over the years..
You basically have a cable assembly and one end is already connectorized/overmolded with flying leads/stubs out the other side right?
Got a picture or something..
I know there's a lot to be desired.. I'm just hoping someone has a better solution before I implement what I consider a very clunky solution..
For example, we use a power cable like this:
I need to demonstrate where these leads are landed after it passes through the cord grip into the enclosure. At the moment the only way I can figure to do this is create pin locations hidden within the overmolded connector to connect the other end of the wires...
Well.. Sounds like a plan.. Thats actually what it is in real life...
I'd just model the plug.. Extrude a hole in the end and throw the pins down in the bottom of that hole.. make it deep enough so your segment,ends all hide down in there nicely..
I might whip one up and see how it works myself doing that.. Should be just fine.. Not really clunky.. Its how it really is..
Quickly but yes.. Its simple.. Maybe make a point a bit recessed in the plug hole to act as a point for the segment to keep it in there and be done..
While that's true that it's how it actually is.. it's not part of the process that I need to demonstrate.
Maybe I'm just being too picky, but here's a power supply with an overmolded cable/flying leads. When I pull it into a nailboard/idw, it's shown in a way that's going to be very confusing on a manufacturing drawing. I can do some manual edits on the drawing and add notes to clear it up.. but then I have to do that for every single overmolded component I use (which is quite a few and quite often). Just hoping for a better "best practice" before I move forward doing them this way..
As a side note, I'm currently in 2015 - so if there's anything new with this in 2017 I'm not familiar with it, but I could move this to 2017 if it's worth it.
Wouldn't matter if you had Inventor 2008 or even earlier NOTHING has changed..
A single pin right at the entry of the cable would work too and avoid your "recessed" look/confusion in the nailboard..
Hello @Brendan.Thorpe,
I have looked over the thread and agree with mcgyvr's comments about the cable and harness environment lacking this functionality. The only thing I can suggest is to post this request in the Inventor Ideas Forum to be considered for future release. The product managers there do monitor these requests and I would like to see these types of issues at least presented to them showing these challenges.
Don
