Optimise a model for 3D printing
DLambertW27TJ
DLambertW27TJ
I have been asked to find a way to provide a model of an angled front panel, (which will later be injection moulded), for 3D printing while we refine the design. The idea is to print a flat panel, which can then be folded to the correct angle on assembly. I have done this by changing one dimension, (13deg angle) in a sketch, as in the images below:
... however there is a further request to incorporate other parts into the 3D print, to be printed as a single part. I have tried making an assembly & incorporating the parts as a Direct Edit. In both cases the additional parts maintain their position relative to the original angle (13deg), see images below, at 13deg & flattened to 0deg.
Is there any way of linking this sketch dimension so that I can use one model for both scenarios, ie, printing & assembly.
Inventor Help_03.PNGInventor Help_04.PNGInventor Help_05.PNGInventor Help_06.PNG
best regards,
Dave L
WHolzwarth
Is there any way of linking this sketch dimension so that I can use one model for both scenarios, ie, printing & assembly?
I could think of this way:
- Place all parts in an assembly. Base plate still has 13° bend
- Make a derived multibody IPT of that, with separate bodies
- Do a boolean combine (join) of the bent region and the parts, that are placed there
- Bend this part of the whole system to flat
Now 3D printing should be ok.
Walter Holzwarth
SBix26
Making it an assembly should work.  If the additional parts are constrained to the 13° section properly, they should move with it when it changes angle.
Any chance you could post the assembly and parts here?  Or a simpler demonstration assembly?
Sam B
Inventor Pro 2024.2 | Windows 10 Home 22H2
Frederick_Law
This can be print at 13 deg with support.
Powder and resin will have no problem printing also.
Print one and test if it'll bend at 13 deg.
DLambertW27TJ
Hi, the first ones were printed like that & you're right, it's no problem for the printer to provide supports. We are just trying to streamline the process with a view to possibly 3D printing some parts for production later.
Frederick_Law
You'll need to consider:
Support will need to be removed, easiest is dissolvable support.
With support, all the boss will have a flat surface.
Without support, the part need to be bend after print.
A locking mechanism is needed to keep it "bent".
The bend will be a weak point.
All the boss on the "bend" side will print at angle and will become stair case.
You have a few trade off between the two.
DLambertW27TJ
I might be able to send a simplified model later but right now we're a little busy. So far in the assembly version the additional parts do not follow the surface they are attached to when the angle is modified in the Panel.ipt
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
