Opening DWG in Inventor or Autocad
I am working with Autocad and Inventor to update our drawings.
When i worked with Windows 7, the system seperated the old DWG files which were made with Autocad with drawings I made with Inventor.
When I opened a drawing that I created in Inventor, it opened the DWG file in Inventor.
The old files that were made with Autocad in the past, my computer opened it with AutoCAD.
I recently upgraded to Windows 10 (bit late) but now i encounter the problem that my system does not see a difference in file format as they are both DWG files.
I can save the data from now on in an IDW file, but there are lots of drawings that i created in Inventor that i still want to open in Inventor when i click on it.
Does anyone know if there is a setting I can change to let my computer know that there is a difference between DWG created With Autocad or created with Inventor?
Dnyaneshwar_Maid
Please see below link and check and follow the procedure type which will be suitable for you.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/DWG-fi...
It should work for you.
Best regards,
Dnyaneshwar Maid
Dnyaneshwar Maid
Design Engineer @MIBA,
Student Expert@Inventor
johnsonshiue
Hi! I believe your Windows is probably confused with which application to open the dwg. Try this. Go to File Explorer and find a dwg file. Right-click on the dwg file -> Properties -> General -> Open with -> Change -> select AutoCAD DWG  Launcher.
Many thanks!
Software Test Engineer
Hi
It works like a charm! Thank you very much!
it now sees the difference between the 2 files.
This makes opening .DWG files alot quicker.
Fine day 🙂
