Opening a Step file
Opening a Step file
NigelHay
Advisor Advisor
Opening a Step file
NigelHay
More an observation than anything, I've noticed that if I open a STEP file in Inventor I get a dialogue box asking if I want to open as parts or composite etc. If I select multiple STEP files, there is no dialogue, the parts just open as .iam. Why the difference?
Inv2017
Win 7
YannickEnrico
I don't know why they chose to do it like that, when they could've opened a dialog for each as easily.. But from what I've seen from Inventor, it'll stick to the options.
So if you setup the options for the first step file, and then open the rest, it -should- handle them the same way.
To answer your question, I believe it's a design choice, although I don't know enough about programming to be certain.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
NigelHay
I didn't select any options, just multi selected files & opened. Would it remember options from a previous Inventor session?
YannickEnrico
Just tested.
It will save these options between sessions, it seems. Might not if I restart the computer though...
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
johnsonshiue
Hi! Indeed, the options persist within the session across different import file types.
Many thanks!
Software Test Engineer
NigelHay
I opened a group of 4 STEP files yesterday & again they opened without any prompting even though my PC had been powered off over the weekend. It still opens the dialogue if I open only 1 file which, I guess, makes sense otherwise you could never access the opening options.
