Open an Assembly in Parts only format in Inventor's Design Assistant
Rishi-Bhardwaj
Rishi-Bhardwaj
In many cases I have to rename many part names with design Assistant, So, I want to open my part list in Design Assistant in a parts only format same as shown in the bill of material part only environment. If it is possible to do that than, it will be a great help for me. Please help me to do that, if possible. Thanks in Advance.
Gabriel_Watson
You can search by all part files within specific folders in the Design assistant, and filter by whatever is IPT (delete other criteria lines, and add Files of Type IPT, also making sure to search in the right folders):
Or pick a folder/subfolder with all files within (File > Open folder), but that is probably not what you are looking for.
In a perfect world, you would use Vault for this. Selecting one assembly allows you to see what it uses (sort of like a BOM/Parts List) under the "Uses" tab, and there you can select multiple files to rename.
Rishi-Bhardwaj
Thanks for your reply..
