I have a sheet metal part that has a few cuts on the faces. I am trying to create offset geometry, and currently I have to select each line segment by itself, then project this geometry, then create a new line of arc for each segment, then make them equal or colinear, and then I can select the loop and make an offset.
Sorry for constantly comparing Inventor to Solidworks, but its the best reference I have.
In Solidworks, when you project geometry, it turns into sketch geometry (no need to recreate it) Seecting loops, and tangency in Solidworks also makes the selection process much master.
If somebody has some tips that can speed this process up, it would be much appreciated.
Todd
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
