Offset 2D Sketched Spline
machiningllc
machiningllc
I was wondering if anyone has had an issue offsetting a 2D sketched spine. For some reason I can online offset in the positive direction not the negative. To be clear it does let me offset in the negative direction but only like .007".  Attached is the pack-n-go of the part.
jhackney1972
If you are talking about the part Broken.ipt, the sketch cannot be offset in a Negative direction, inside the part, because it overlaps itself and becomes a segmented circle.  There is no issue with the sketch offset command. If you want the sketch to be the same shape but smaller on the inside, use the sketch Scale command.
Next time you post a single Inventor part, do not use Pack and Go.  You use Pack and Go for gathering Assembly files along with all their associated parts.  When you do use Pack and Go, make sure you check the two indicated boxes.  No one wants to see your templates and Design Data.
John Hackney, Retired
machiningllc
Well you nailed it. Thanks for your reply but it offsets fine in Fusion. Not sure why it just does.
JDMather
Can you File>Export and then Attach your Fusion  *.f3d file here?
johnsonshiue
Hi! Without seeing the file, I can almost tell it is probably due to curvature or tangency of the spline. In some section, the inward offset might cause change in topology (one curve has to become two curves or there has to be a sharp corner). Inventor Spline Offset does not know how to handle it.
The workaround is to Extrude the source spline as a surface. Next, use Thicken/Offset command to offset the surface body inward. Then, project the edge to a sketch.
Many thanks!
Software Test Engineer
