Odd issue with 2017 update
JRW.BGB.USA
JRW.BGB.USA
Ok so long story short, had to reinstall INV2017 and I need to put the update packs back on but they just wont install.
I have an up to date windows 10 machine and I am using the browser down loaded .exe packages.
I double click to the exe, it loads the window below "Inventor 2017.4 Update, modify set up" and that's it!
I left it to run like that all last night and it didn't install.... just seems to hang... any ideas?inv2017 update.jpg
johnsonshiue
Hi! The behavior does not sound right. Please go to %temp% folder, find the update install log file, and send it to me directly (johnson.shiue@autodesk.com).
Was it installed as an .exe or .msi? If it was .msi, you might need to uninstall Inventor 2017 and reinstall 2017 and 2017.4 update.
Many thanks!
Software Test Engineer
JRW.BGB.USA
Apologies, I didn't realize I had a reply to my question. Unfortunately, I still have the same problem. Would you be able to help me by clarifying the exact file you need me to send you?
I am having this problem with the .exe for Inv update.
Mark.Lancaster
@JRW.BGB.USA
In your personal temp (%temp%) folder C:\users\<username>\Appdata\local\temp should be log file associated to this update 2017.4.   Attach them here for review.
Mark Lancaster
