Hello everyone,
Happy new/old year!
I want to dive deeper into learning the simulation and i've came up with the task.
The objective is pretty straight forward - i want to know force values at the specific point at specific angles which is needed to open this hatch door which weights 200kgs... It will be opened by a electric linear actuator, and thus in order to save time/money i need to know the maximum force required to lift the hatch door, before buying an actuator.
I'll upload a short video demonstration of the situation as well as the pack n go files of the situation.
NOTE : the multiple joint hinge is not modeled by me.
Can someone point me into right direction (YT tutorials, or autodesk tutorials) where i could learn to set up that kind of situation in the Inventor or where i should start atleast to make some progress ?
Solved by johnsonshiue. Go to Solution.
Hi! I am not sure if you have watch the following tutorials. Please take a look.
Crimping tool by JD Mather
https://www.youtube.com/watch?v=SuEEs33_hEI
https://www.youtube.com/watch?v=EHP5dkzd3OA
https://www.youtube.com/watch?v=gVdCddnbNK0
Dynamic Simulation tutorial by Constantin Stancescu
https://www.youtube.com/watch?v=HGnKkVziqjc
Many thanks!
